Step 7 and wincc flex dealing with timer preset help
Jeff23spl
Jan 2010
Canada
860
Hello
I usually represent all my time delay in 0.001sec inside the hmi but know i need to enter values ranging to 2o minutes meaning 1200 000ms!!!
I'm using S5time variable and equivalent timer tags on winccflex for timer preset values
Do someone know a better way of doing this to fix or choose the timer preset base units
Use the IEC Timeers instead of the S5T timers, they take their input directly in ms and you don't need to worry about BCD or range coding which makes them much easier to feed (more or less) directly from the HMI.
i try to run simulation between WinCC flex and step 7 is that possible if u dont have real stuff? i followed some guide on the internet but...
8,418
Hello there, I need to find a fault in a system where the s7-300 and siemens hmi panel are interconnected. Alarm number 327 is triggered via Wincc...
3,907
At the end of the day today I did my first program edit in my customer's Simatic Manager project. It was the simplest of edits... add a bit with a...
2,321
Tomorrow morning I have to use a rented Siemens PC to troubleshoot a Siemens HMI, programmed with WinCC, communicating to a couple of ABB drives...
10,124
Hi folks, I'm new to Siemens and I have a couple questions: 1) In Step 7 -> Data Block : I try to read/write a bit in a word (like in RSlogix500...
5,382
