How to simulate between WinCC Flex and Step 7
It is an image of a smartaccess connection to a panel. It has nothing to do with simulation.
You need to have the PLCSIM option to STEP7. To simulate a complete PLC and HMI project you need to do this:
Set the PG/PC Interface to S7ONLINE=PLCSIM(ethernet), or S7ONLINE=PLCSIM(MPI), or S7ONLINE=PLCSIM(DP).
Start PLCSIM.
Download the S7 project to PLCSIM.
Set PLCSIM to RUN.
Start the regular runtime in WinCC Flexible, not the simulated runtime.
And that is it.
Regular runtime with one is that? i have 3 button
1. with a screen with a play button , start runtime system
2 the one look like pair of sun glass, start runtime system with scripts debugger
3. Start runtime with simulator
i have integrate the project in to step 7 project , and downloaded to the plc sim, but when i hit
tranfer button in winCc i only get error connection.
i am sitting behind a router the dude in the video
http://www.winccflexiblemastery.com/
Basic of Grafic Design
Module#2 Video 3 integrating WinCC Flexible Project in Step 7
showed that i need to change
cpu ip adress, and use ethernet, and change static ip adress do u need to that when u use MPI?
i did all this
Start PLCSIM.
Set PLCSIM to RUN
i have setbit in WinCC to the S7 project but, when i push the button in HMI panels nothing happen
in step7
MPI and ethernet what should i choose, if i choose ethernet do i have to change plc sim to tcp/ip?
Dont start transfer.
You must set S7ONLINE=PLCSIM(ethernet), or S7ONLINE=PLCSIM(MPI), or S7ONLINE=PLCSIM(DP) depending on what online connection there is between panel and S7 CPU.
Then use the 1st button you mentioned.
Hi all, i'm pretty new in this field. For university purpose i have to develop a IDS ( or maybe just some snort rules) for scada systems. so i...
2,968
Hi there, I'm doing some extensive testing and commissioning with a slew of new Emerson PACSystems RX3i PLCs. It would be convenient to...
111
Hello, I have a small application with a S7-1200 CPU 1212 and a KTP400 Basic HMI. When i am connected to the PLC with my PC i would like to...
547
Hello everyone, i would like to test and run os server in pcs7 v8.2 project without rear PLC.i used plcim on ES and nettoplcsim and adjust the...
1,336
Hi all, Im new to Allen Bradley software, so i was given a existing studio 5000 plc program. i already know how to use emulator and rslinx but as...
1,416
