IMC120 ODS.EXE on Windows 7?
NEETECH
Nov 2017
Greenville
Hello,
I have been attempting to migrate our software to new computers and I have been stumped with the program we use to load IMC120 controllers. The ODS.EXE works on windows 98 perfectly, but when I moved it to an XP machine or Win7 they both had trouble finding the DF1 driver. I have the df1drv.sys installed. I believe the config.sys should set that up but every time I edit the config.sys file and save it to the Win7 machine it seems to disappear and still won't work. I've tried a dos emulator but that seemed worse.
I hope someone knows of an approach I can take to get it to work or if its futile.
Thanks in advance.
VMWare is a good program but non-free.
Virtualbox is free and generally works great as well and I would strongly suggest you give it a try.
Just install Windows 98 into a virtual machine using the license from your old computer (as you aren't going to be using it anymore) and then load your program. You can pass the serial port directly into the VM. Just remember, you can't use the same serial port in your host OS or guest OS (Host is the main computer, guest is the virtual machine). This amounts to making sure no program is running on the host OS so that the guest OS can take control of the device.
Hello.
Please, give me a lot of df1drv.sys
my email [email protected]
Could you send me the ODS installation version?
I will be very grateful.
greetings Piotr
Sorry for English I use a translator
I would like to communicate with IMC120 but do not have a cable.Would someone be kind and help me in giving me the pin-out of the cable so as make...
1,958
Does anyone by chance know what the name of the software is that I need to change parameters in an IMC120 Allen Bradley PLC. I'm going from a 4...
3,328
Greetings. I want to install a PLC with servo and photocell. For a plastic bag cutting and sealing machine, logically it will work with printed...
128
Hello, I have somewhat minimal experience tuning PID systems. Ive done a small servo controlled camera gantry. In the process of tuning sometimes...
3,179
I would like to use this thread to ask for opinions on methods/practices. I am starting on a fairly large complete rewrite of code for several...
2,431
