IMC120 Software
doc_egbert
May 2006
Barnard,Missouri
Does anyone by chance know what the name of the software is that I need to change parameters in an IMC120 Allen Bradley PLC. I'm going from a 4 machine cell to 6 and need to extend the range of the IMC boards. Thanks, Doc
It appears that this PLC-based motion controller uses a DOS-based software called ODS. A tech note on the Rockwell Knowledgebase says that this software *must* be run in a DOS shell.
Each machine has its own ODS software, and I believe the part number for the IMC-120 ODS is 8100-HSKAR.
Rick
i need help please
doc_egbert said:
Thanks Rick. After you told me what the name of it was I remembered we already have it loaded on the laptop. Bill
Hi this is Gerardo from delphi Mexico, i'm having several problems with this card, my baterry is died and i need to make a back up of the memory to do that i need the software i read here that you have this software, could you give a copy in order to solve my problem? i will appreciate so much. thanks in advance, my email is [email protected].
Thank you again.
Hello, I have been attempting to migrate our software to new computers and I have been stumped with the program we use to load IMC120 controllers...
1,758
I would like to communicate with IMC120 but do not have a cable.Would someone be kind and help me in giving me the pin-out of the cable so as make...
1,946
130
Hi! So my problem is a little funky, I had Studio 5000 v 24 and 30 installed, but forgot to install RSLogix (which I cannot go without). Is there...
124
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
111
