AB license dongle w/ multiple licenses of RSLogix 500
kolyur
Oct 2004
Wooster, Ohio
1,602
We have a dozen or so Maintenance technicians who have their own laptops and need access to RSLogix 500 (Starter). Some of them use it very infrequently, so I'm looking at getting the 9509-USB-DONG2 dongle to allow some of them to share the same license. (Thanks to Geospark for his detailed posts about how this all works.) There may be times when multiple dongle users need to run the software simultaneously, so I'd like to have more than one dongle available--possibly up to four, each with its own license. My question is, would RSLogix run seamlessly with any of the four dongles inserted? I ask because I know that when you install RSLogix you have to enter the serial number, but now I would have multiple serial numbers to choose from and the software S/N wouldn't necessarily match that of the license on the inserted dongle. Is this doable?
We don't use the dongles, but we have the licenses running on the FT Activation Server on the network.
When we install RS5000 for example, we use the serial number for one of the licenses and it seems to work just fine even if it checks out a different license/serial(assuming the same activation 'level').
I can't say for sure, but I don't see why it would work differently for the dongle.
The serial number you enter when you install the software means nothing. You can literally enter any 10 digit number and it will install. The serial number in the licensing server is what determines if its licensed or not.
There may be times when multiple dongle users need to run the software simultaneously, so I'd like to have more than one dongle available--possibly up to four, each with its own license. My question is, would RSLogix run seamlessly with any of the four dongles inserted? ... Is this doable?
Absolutely.
The key is when you set them up you need to copy all the *.LIC files to the proper activations folder on each computer (default is C:\Users\Public\Documents\Rockwell Automation\Activations).
I have the older dongle style which didn't have memory on it. The newer DONG2 has memory and I believe you can keep the license file there. Never tried it myself. See KB505357
The HMI software's run-time USB license key has nice hole in the end. What do you guys use to secure it so it doesn't walk away?
2,057
Good morning- I am having an issue I find strange. I had version 20.03 of RS 5000 on my computer and i needed to load 17.01 to look at an older...
2,053
Hello, I have an RSView32 project running on a Windows XP. The licenses for RSView32 runtime and RSLinx are provided by a dongle. I tried to move...
3,231
Hi Everyone, I own a GE Versamax controller that I purchased for a class at Long Beach City College a couple of years ago. I lost the use of my...
92
I have a problem, I'm running an AE Licence Manager on a Windows 2016 Server, and my Window Maker is on another separate Windows 2016 Server. My...
74
