PLC Programming
What looks a little strange is that the IN to the timer is true and the it looks like Q is true as well but the elapsed time is 0. Could you be using the Tag
Timer
somewhere else in your program?
Or, what are you using to turn on S2? did you load my simulation program? Are you forcing values? Could S2 be chattering on and off very fast?
I would use TON timer on this and RS1 output Q1 as input on it. Also i recommend to detect only rising edge of start command S2. This is just one possible way to do it:
261
Hello colleagues, Some time ago I started my adventure with programming. With your help and the courses, things are starting to come together...
747
Dear All, I need a sample PLC program to count the output pulse of a mass flow meter so that a specific amount of mass (for example 100gm)can be...
177
Hi Please I have zeilo smart relay #SR2A201BD but I don't have it's programming cable. Can I use any general usb/rs232 converter? Or need...
184
Hi, Does anyone have thoughts or know of, can point in the right direction any published materials with a plumbing centric point of you explaining...
186
