GX Developer to RS500
norman oliver
Oct 2013
sutton coldfield
33
Hi all, Here's an easy one. I've been asked to change a mitsubishi FX plc to a AB1400 using the same program. My customer has emailed me the latest uploaded mitsi program but as I haven't got any up-to-date Mitsubishi GX developer s/ware I cannot open the program to transpose it to RS500.
I've attached the emailed program and if anyone out there has the relevant gx developer s/w could they open it, save it as a PDF file and email it back to me.
I would be most grateful.
Hi IAutomation
Thank you so much! The lack of comments etc is not a problem as I wrote the program some ten years ago and have the original details. The program has been modified using a newer version of s/w than mine.
Once again - many thanks
I'm trying to verify a project with a PLC. The Transfer Setup menu item is grayed out and every time I click Verify with PLC, I get an error...
47
Well, I've decided to start a new project, and like all projects, it has already gone horribly wrong. I purchased a PLC device (supposedly a...
111
Does anybody have any samples of how to "Create and Use" UDT's in CCW Developer Edition? (I am using v22) I can't find any information from...
312
I'm trying to manually convert a Beijer E200 HMI project onto to a new Mitsubishi GOT gs2107-wtbd. The PLC is a very old A-series AS1CPU and is...
381
Hi One of the PLC's that I maintain/update is a Mitsubishi Q-Series, probably installed about 10 years ago. At the moment, ALL the wires from...
1,171
