PowerFlex 40 - Can you use DeviceNet , but also use the Analog Output ?
Cydog
Feb 2018
Maryland
313
Good Afternoon,
I have a few PowerFlex 40 drives that are being controlled by Devicenet.
I was wondering that if you are controlling a PowerFlex 40 with Devicenet could you still use the Analog Output ( A 065 ) ?
Thanks so much ,
Why wouldn't you be able to use the A065 Analog Output ? That physical analog signal channel is designed to send out a signal proportional to the drive's output frequency, current, voltage, or power. You can even set it to send an arbitrary test data value.
If you're talking about using the network speed command and reference as well as an Analog Input, and switching between them or using one of them as a trim value, then that's a different question.
Thanks Ken . So even if Devicenet is being used to start , stop , frequency , etc. , I can still use the Analog Output ? Great .
Thanks .
Hi there, I have above mentioned VFD which is communicating to my control logix(L62) plc using devicenet DNB scanner(plc side) and 20-comm-D card...
170
Something i ran into that has me stumped, hopefully someone can explain. I have powerflex 70's connected to a L7 cpu using a 1788-en2dn. The...
1,398
Hello all, It's been a while but have an odd request. Have a customer that has a AB SLC5/05 with a SDN module. On the network are several...
1,214
Hi all I am working on a retrofit project. There is one backup pump with Powerflex 753 drive controlled by 2 different PLCs(one 1756-L63 ,one...
1,578
I'm having a strange issue where the operator can input a desired speed in 0-110%, and the scaling will correctly translate that in Hertz to the...
2,350
