Communicate with plc mitsubishi fx series
thiba007
Jul 2011
KUALA LUMPUR
Dear all,
I got once issue where by i need to monitor a Auto Hoist that use
Mitsubishi FX2N Series. My problem is to do ONLINE MONITOR the PLC
since the hoist is moving Forward & Reverse after pick the parts.
Is there any wireless communication device from Mitsubishi maker.
Please advise on this.🤞🏻
Something like this should work :
http://www.usconverters.com/rs232-serial-wifi-adapter
FX2N programming port is a serial RS422 port.
The converter lets transmit the serial data through the Ethernet/WiFi network.
Installing the virtual COM software in the PC you can connect the programming software to that virtual port as if it were a real port.
Probably there are also other cheaper adapters Made in China ...
Hi men! I need know, which HMI i can use with PLC Mitsubishi series A ?? factorylink ?? intouch ?? indusoft ?? CitectScada ?? Elipse ?? i have...
6,194
I have created a program that collects counter valves and assigns a date time stamp to the counter value using the real time clock. This...
7,024
Hello i have a PV+1000 firmware ver 5.10 and a compact logix L18ERM VER 24. I googled and read many posts but still can not make simple button on...
557
Have matched communication parameters of both, DOPSOFT HMI and PLC Fatek. Yet an error keeps appearing "Failed to open port COM1". I believe...
685
