Help with QR Scanner RCV data
Big_Robo
Nov 2016
England
81
Hello, I have set up a cp340 with a keysence QR Scanner.
I am recieving some weird data and I'm not sure how to solve it.
I'm trying to split the incoming data from DB61 and put it into DB65 so I can read the data.
When I fire the scanner this is the data I receive is 16#00000020 for all bits.
Any help would be appreciated.
Are you sure the data is 20 ? i.e. are you preloading the DB with (say) FF before receiving data?
I don't believe DB is pre loaded. Just did a quick test firing the QR Scanner without a barcode to read gives me the 20 value same as with barcode so now I'm sure it's not reading correct
Carriage return possibly? What model is the keyence? Use Auto ID (network) navigator to check the send strings and CR's
Go to www.barcodereader.com (not keyence website direct) and download the sample program for S7-300 and also auto ID network navigator which should have a template file for use. The SR1000 does not work without some config out of the box. I have used them but unfortunately not with Siemens.
Thankyou for the reply, really appreciate it. will have a look and see.
Thanks again
Hello, I have a device with 68 words input. But one block on the Devicenet Scanner is only 61 words. I am trying to map this device to 2...
549
Hello, I am setting up for practice and I am having trouble seeing the 1771 Scanner in RsLinx as well as Rsnetworx My setup: slot 0 : PLC-5/40E...
1,003
hi, i try to connect to sick clv490 barcode using controllogix serial port but i can get it to work. im using ascii read port 0 but nothing.
1,219
What i am using: Rack 1: 1,slc500 cpu 5/03 slot 0 2, 1747-sn scanner ser:b slot 1 3:16 pionts ac input slot 02 4:16 points ac input slot 3 5:16...
1,863
Hello there, appreciate if someone kind enough to teach me or show me how to solve this problem. Realy headache with this.. Thanks!! =) I'm...
8,344
