1771 SDN/ C DeviceNet scanner help
BeepBob
Jan 2023
Oakland, CA
107
Hello,
I am setting up for practice and I am having trouble seeing the 1771 Scanner in RsLinx as well as Rsnetworx
My setup:
slot 0 : PLC-5/40E
slot 1 : CoPro
slot 2 : 1771 SDN/C
the chassis is setup for 1-slot addressing, the scanner is setup for 1-slot addressing (switch 8 under Configuration is “on”). Address for channel 1 is 0 and address for channel 2 is 1. The scanner should be located at Rack 0 Group 1 Slot 0
Can anyone point out what I am doing wrong ?
I’ll add some screenshot
Like all other 1771 modules, the 1771-SDN does not appear in any kind of browse or auto-detection across the PLC-5 backplane. Folks are spoiled by 25 years of Logix.
To see the DeviceNet port of the 1771-SDN In RSLinx and RSNetworx, you will need to apply 24V DC power and connect at least one slave device to one of the ports of the Scanner.
I don't like or recommend the 1771-SDNPT Pass-Through driver; you will be far better off with a 1770-KFD or 1784-U2DN.
I realize now that you're the Forum member with the mix of archaic and modern stuff to mix: DNet with the PLC-5 and ProfiNet for a planned S7 migration.
Get out some graph paper, you're going to need it !
haha yes sir!
I added one device to the network, and applied 24v power, now the LED displays just error code 78, which is “slave device not on scanlist” which makes sense.
Now what I tried to do, is create a DeviceNet driver in Rslinx, through the PLC5, so that I can browse, but sadly I see nothing in RsNetworx
We have field PLC5 with 2 scanners in the chassis and the above step is how I browse the devicenet network and it works fine. What am I doing here that is different than the PLC5 that we have in the field?
Ahh I see, what we have been doing is the 1771-SDNPT Pass-Through driver that you mentioned, and it isn't recommended.
I also have a cable that plugs into the devicenet scanner ontop of the line plug. I will try that next.
Searched the forums , but didn't see anything remotely similiar so here goes: I've got a 2 node DeviceNet setup. One is the 1771-SDN on the PLC5...
3,303
Hello, I have some experience with AB hardware and networks, but I need to add a Danfoss VLT5000 drive to an actual DeviceNet network, scanned...
2,540
Hi, Whats yours thoughts or experiences on buying used PLCs parts from Ebay? Had any success? I need a 1771-SDN Devicenet scanner to add about...
4,060
We have an Allen Bradley Powerflex 70 Device net drive connected to PLC5 1771-SDN module. The replacement drive is a much newer firmware so I need...
2,611
Hi, I have to use a 1771-SDN devicenet card for a remote control panel which is controlled by PLC5000. Now, it looks like 1771-SDN is used for...
19
3,702
