Powerflex 527 drive setup in IO
ziyaddin2015
Nov 2019
USA
84
I am trying to setup the new powerflex 527 to use for training purposes but it wouldn’t let me to finish adding it to an IO and I would get an error saying time sync which I made sure was enabled. I don’t why it would still said it’s an issue? Also, can I just add drive to an IO tree in studio without a motor? I am using 1756-L72 controller, en3tr and studio 5000 version 33. Thanks
63BDF91C-7A8B-4B15-9A6F-38BAD9A9DCF6.jpg 1797FE0B-8F06-48D4-83F9-2DA3A17BB11A.jpg 0B0332D5-64CA-468C-8D78-E4B69789A087.jpg
I swapped out a PF 527 drive that has been giving me occasional faults. I replaced with a new 527, assigned its IP and gateway and cycled power...
2,027
Hi, I am having an application in which we are having a Roller rotating via Powerflex 527 drive. The operator can change the speed of this roller...
4,535
We plan on having a stationary panel with a PLC , 3 Powerflex 527 drives , with the incremental encoder from the motor to the encoder option card...
3,458
Hi all, I am having issues with a Powerflex 527 STO. I am hard wiring a safety relay (guard master MSR27TP) to S1 and S2 and also the common to...
1,800
I've got motor that ran fine for years, but now it's sarting to overshoot its target position a few times a day. Is this indicative of a motor...
24
5,754
