VB2012 RsiOPCAuto.OPCServer
SourceGin
Sep 2014
Grottoes Va
I've Started a VB2012 Project Looking at a OPC Topic in Rslinx Just wanting my tag value to show up in TextBox1.Text Any Idea's why it isn't or anyone have a better Code base to accomplish this / (y)
'//Using RSiOPCAuto.dll
Imports RsiOPCAuto
Imports OPCAutomation
Imports Microsoft.Office
Public Class Form1
Dim MyOPC1 As RsiOPCAuto_OPCServer
Dim WithEvents OPCServer1 As RsiOPCAuto_OPCServer
Dim WithEvents OPCGroup1 As RsiOPCAuto_OPCGroup
Dim MyOPCItems() As RsiOPCAuto_OPCItems
Private Sub Form1_Load(sender As Object, e As EventArgs) Handles MyBase.Load
'Dim OPCitems1 As ArrayList
MyOPC1 = New RsiOPCAuto_OPCServer
'OPCServer1 = New RsiOPCAuto_OPCServer
'OPCServer1.Connect("RSLinx OPC Server")
'OPCServer1.Connect("RSLinxEnterprise.OPCServer")
MyOPC1.Connect("RSLinx OPC Server")
OPCGroup1 = MyOPC1.OPCGroups.Add("REPORTING")
'ReDim OPCitems(1)
MyOPCItems(1) = OPCGroup1.OPCItems.GetOPCItem("[REPORTING]COUNTDATA2.ACC")
TextBox1.Text = MyOPCItems(1)
i have an Complete Completed Project for Logix 500 and XP i was trying to Re-Develop For Logix 5000 on VB.NET 2012
After 24 Hours Of Coding i have it solved for Logix 5000
Anyone need assistance on Development Please Don't hesitate to Contact me ("VB6 / Delphi / VB.NET / ASP.NET / C# / PHP / ASP / PYTHON / PERL / BATCHFILE / POWERSHELL ") in Automation
Currently working on a Python OPC Server and Client
'//----------------MY SNIPPIT--------------------------------
'Tagvalue1Txt.Text = DATAVALUE1.ACC
'This is run when when the called from the btnConnect_Click
'Define OPCTopic to create the proper format for the OPCTopic to look like [OPCTopic]
Dim OPCTopic As String
OPCTopic = ("[" & TopicTxt.Text & "]")
'Create a new instance of OPC Server and call it OPCServer1
OPCServer1 = New OPCServer
'Now connect to the OPC Server we just created
'Create a new OPC Group in the previous defined OPC Server
OPCGroup1 = OPCServer1.OPCGroups.Add("REPORTING")
'Set the Group to the Active State for Updates and Events
OPCGroup1.IsActive = True
'Set the Update Rate of the OPCServer 1000 = 1 Second, which is the Default
OPCGroup1.UpdateRate = 500
'Instruct OPC Server to send OPC Group data Changes
OPCGroup1.IsSubscribed = True
'Add an Item / Address Point to the OPCGroup we just created
'"[RSLinx_Topic_Name]PhysicalAddress or Symbol if Symbols have been imported to RSLinx
'the ", 1" is the Client Handle RSLinx will get this first, the next one will be ", 2"
OPCGroup1.OPCItems.AddItem(OPCTopic & Tagvalue1Txt.Text, 0)
' OPCGroup1.OPCItems.AddItem(OPCTopic & "S:4", 2)
OPCServerConnected = True
End Sub
Unable to connect RSLINX Classic OPC using C#.NET
Hi
I am trying to create a test connection to RSLINX classic using C# code but I am getting exception when trying to connect.
Exception :{"E_NETWORK_ERROR\r\nCould not connect to server."}
InnerException: {"CoCreateInstanceEx: Class is not licensed for use\r\n"}
Please find attached screen for code related onformation and help me to sort out this issue.
Thanks,
Venkatesh Gude.
My first guess is that you only have RSLinx Lite which is not licensed for OPC use.
Hi Archie,
I just have RSLinx Classic installed on my machine.
Does it mandatory to have RSLINX Oem or Pro versions to connect from .NET applications?
I also observed an exception related to referenced dll(Interop.RsiopcAuto.dll) when executing below line
RsiOpcAuto opcsrvr=new RsiOPCAuto_OPCServer();
Exception details :
Retrieving the COM class factory for component with CLSID {DFB8323C-A952-11D2-A46B-00C04F796375} failed due to the following error: 80040154.
please suggest ways to get rid of this problem.
Thanks,
Hi all , What im attempting to To is to have my RsiOPCauto.DLL in which has been Added to my VB2010 Solution and Connect to a remote RSLinx...
2,588
Hi all. I am creating a dotnet application with RsiOPCAuto.dll, and I have managed to read and write tags value. But today when I wanted to...
2,374
Hi I am trying to retrive RSLINX data from c#.net application. I have refenced my .Net application to Interop.RSIOPCAUTO.dll. But when trying to...
2,591
hi, I want to see if anyone can help me find a bit that indicates Status Online or Offline connection OPC server "OpenBSIOPCServer" Bristol...
1,350
Hello to all, I am trying to collect some data by using OPC Server from few different systems and put them together. I have problem with one of...
3,527
