vikas1947 Member V Join Date Jun 2011 Location india Posts 172 Apr 16, 2018 #1 where do i find FTVIEW HMI Enhanced graphic as per attached HMI screen snapshot i had tried its library object but they are not similar to this .
nhatsen Member N Join Date Oct 2010 Location Argentina Posts 686 Apr 16, 2018 #3 vikas1947 said: where do i find FTVIEW HMI Enhanced graphic as per attached HMI screen snapshot i had tried its library object but they are not similar to this . Click to expand... You can design similar graphics using an image, some numeric indicators and a line (with rotation). It's better if you put everything inside a global object: that way you can dynamically change the scale and use the object in different displays.
Ken Roach Lifetime Supporting Member + Moderator Join Date Apr 2002 Location Seattle, WA Posts 17,494 Apr 16, 2018 #4 Those are almost certainly custom graphics with FTView native objects (like the dial pointer) superimposed on them. They look great, but I strongly doubt you're going to find them in the built-in libraries (even the Symbol Factory library).
vikas1947 Member OP V Join Date Jun 2011 Location india Posts 172 Apr 17, 2018 #5 Yes bright676 said: Is that in a car?? Click to expand... Yes its a aluminum plant cart .
