Number of FtView Se HMI servers allowed on 1 pc ?
One PC may have up to two HMI servers. Functionally I don't believe it will prevent you from adding a third. I seem to recall running more than two HMI servers for demonstration purposes.
But, two is what Rockwell supports. If you are running more, and have an issue, they may say you are not running a supported configuration.
Having support for two was primarily to support redundancy. HMI A could be a primary server for say the bottling process while also being a redundant backup for the quality control process. HMI B then would be a redundant backup for bottling while being the primary for quality control. But they could also be two separate, non-redundant, HMI servers.
OG
Thanks for the info.
Currently, we are running 9 HMI servers off one PC. There is no control involved, the clients are only used for displaying production data.
I wanted to know the high limit, because i have to add about 7 more HMI servers to the PC for displaying.
Hi folks, I have a situation where a popup is called from a global object button with a single parameter. This parameter is a 4 digit hard-coded...
949
I am working on a project using a NB screen and NX1P2 PLC. I am having a really hard time getting a real number to properly translate through to...
121
Complete noob here, using a Click C0-02DD1-D to run a test stand. Requirement is to turn on motor run for X seconds, turn off and dwell for X...
1,085
Hi, I have this weird issue whenever I try to change the SNN from a Point IO Im missing the three ... dots to open the pop up and change it...
619
I'm doing my first PanelView 5000 application with Logix View Designer v8, and am of course jumping in headfirst. One thing I don't find is a way...
702
