My rslogix 5000 does not listed 1756 controllogix contollers
Wahidul Islam
Dec 2017
hobiganj
I have installed rs logix 5000 v 20, and I have a project file (.acd) ehere the controller is 1756-L71..... my software does not contains 1756 controllogix controllers .... if I start a new program then the list don't have that conteoller.
how to update the list of controllers in my rslogix 5000 v 20? can anyone help?
You probably have Mini or Lite version that supports CompactLogix controllers only.
You need Standard or higher activation to see ControlLogix
Features and versions based on the activation level while all installations are the same.
God I hate mini.... I accidentally borrow the wrong activations from our server from time to time and it’s always the mini -.-
Now for the bad news... If you can and you are not already invested... GEt far far far away from V20 or V21 then once you’ve done that, go further. You will run into problems like the one I had tonight where you won’t be able to upload from a controller unless you have the native copy of the program or worse you will have someone make changes with 21.03.xx and you will never be able to get it off the controller again. . However, if you are already invested then just look up studio 5000 v20.00.03 (stick with that version and don’t put any other 20/21 versions on your computer and also don’t let anyone else connect if they have a different version)) and whatever you do DO NOT USE 20.03.xx. I know I am a stranger but please take my word on it.
Hi all, I have an issue with 1756-L62S (revision 20.13) safety lock. We can't figure out who put safety lock on our project. Before I try...
1,041
2,451
The rung in the attached picture reports errors on both instructions. The data type is LINT and it is version 20. If the data type is changed to...
3,405
Hi, I installed RSLogix Emulate 5000 19.01.00 on a PC but it fails at start-up. No error messages during installation. The error message I get...
2,419
