[Rslogix 5000]Does factory resetting 1756-L61S will remove safety lock?
ekdpf0114
Apr 2020
Alberta
Hi all,
I have an issue with 1756-L62S (revision 20.13) safety lock.
We can't figure out who put safety lock on our project.
Before I try something, I want to discuss with some experts here.
I am going to factory reset 1756-L62S by procedure that Rockwell suggested:
To clear a ControlLogix processor memory and revert it to a default condition, simply remove the battery and power down for 5-10 seconds - in any order for 1756-L5x and 1756-L6x controllers series A. <---- I am not sure if resetting safety controller would have same procedures
And then, will download the same but unlocked project to it.
To sum up, I have two questions
1) if resetting safety controller would have same procedures as 1756-L6x
2) if I do factory reset, is controller's safety password going to be removed?
Thanks in advance,
Hi all,
Thanks in advance,
Think you'd be better re-flashing the Firmware. But not sure you can do that to a safety controller.
bubba strikes again.
I would look into how many laptops / pc's has access to the software and system to do this. look at each system and see if there is a backup file and look for the date. this may help you track down the culprit. has any one left recently that had access?
james
Hi all, I have an issue with 1756-L62S (revision 20.13) safety lock. We can't figure out who put safety lock on our project. Before I try...
1,027
I have installed rs logix 5000 v 20, and I have a project file (.acd) ehere the controller is 1756-L71..... my software does not contains 1756...
3,866
The rung in the attached picture reports errors on both instructions. The data type is LINT and it is version 20. If the data type is changed to...
3,367
Hi, I installed RSLogix Emulate 5000 19.01.00 on a PC but it fails at start-up. No error messages during installation. The error message I get...
2,413
