OT Brainstorming... Acoustics/harmonics
LoganB
Apr 2017
Michigan
607
I've just started training to take over a position in the NVH engineering department, and one of the topics in my training today was brainstorming a list of causes for 2nd harmonic noise in small DC motors (those used for window regulators in automobiles).
Does anyone have any insight they could offer? I'm just beginning to wrap my mind around this stuff. The 2nd harmonic is around 250Hz. We're thinking it's a resonance, but not sure the cause.
Thanks in advance!
Keep going.
what is the motor connected to?
what components?
gear box, wire spool, wire, bearings, window, window track...…
is this in all units?
have you tested the motor by itself, no gearbox, just the motor?
food for thought.
james
Motor is being tested as part of a molded door module, but we're hoping to get more data from tests of the motor alone. The system in question is in Europe and we're supporting remotely. I'll follow up with more information when I get more.
I was asking also for just general ideas of what can cause noise around that frequency, as it seems that each harmonic has a sort of "usual suspects" from my extremely limited understanding.
I have a customer that would like a Light/buzzer to indicate when a printer outputs a page. It is for a warehouse setting. The order desk sends...
1,182
Hi All, I am trying to figure out a way to quantify the power required for our machines VFD braking resistors. We don't currently have a way to...
1,309
Dear friends across the pond, Does anyone know which one is the IEEE standard regarding the harmonics performance of the VSDs? Regards Nik
2,114
dear viewers, AS part of power quality in our plant we are studying about effect of harmonics in capacitor panel(apfcr)kindly any of them can...
1,664
Greetings, To what level of Harmonics (THDI) and (THDV) is acceptable in a PLC panel with pressure and temperature transmitters. We have a...
1,804
