24fretslater
Hello everyone.
I'd first like to say that I did in fact search the forums but I didn't find anything that really helped. I have somewhat of a unique situation here.
I'm working on an SBR and am programming a Disk Filter Feed Pump routine.
There are 3 pumps. Filter Feed Pump A, B, and C. I have programmed the Lead and Lag request conditions and now I must program a selectable (From RSVIEW32 SCADA)Lead/Lag/Standby routine.
I am somewhat of a novice at programming and could really use some help! Any reply would be greatly appreciated.
In the event of needing to service a pump, the client would like to be able to select one pump as standby and let the other two pumps operate on normal Lead/Lag sequence.
Kicker is they want to be able to select which pump is lead and which pump is lag as well! Also, the pumps are all on VFD's and if the lag pump is called on, they split the speed control.
I'm very frustrated and overwhelmed seeing as the boss returns tomorrow to see my work. After trying all day it seems I've become quite desperate. Does any one have any tips/templates that might help?
