IFM Sensors going to idle state randomly.
Karinrinkashi
Nov 2017
Atlanta, GA
40
Hello everyone and good morning (almost noon here in ATL),
So, we have a 16-20 oz bottle line that we run at around 1020 bpm on the filler. We have an empty bottle conveyer that uses air to push bottles into the filler. There are 4 sensors on this empty bottle conveyer in order to monitor gaps, and also in case of a lack of bottle supply, to slow down and eventually stop the filler until bottles are restacked from the bottle blower.
We will call these four sensors as follows:
Sensor 1: The farthest from the filler and the first to monitor the bottle presence. If no bottles present, slows the filler down 75% speed
Sensor 2: Second in the line. Same function, but slows the filler down to 50% speed in case of no bottles.
Sensor 3: Third in line, same function, slows the filler down to 25% speed in case of no bottles.
Sensor 4: Last in line, closest to the filler, cuts the empty bottle supply and stops the filler.
All of these sensors are IFM O5G00 sensors with 1 point (On or OFF) or two point (ON and OFF) functions. Some are older than others but they are all the same.
The problem that i am encountering is that all 4 of these, ever few weeks, just go to idle. As if they just went to sleep for no reason, without anyone touching them or factory resetting them manually. And all 4 do it AT THE SAME time.
Reteaching them is no issue at all, but has anyone seen this happen before? My first guess was that maybe there is a short or something in the panel where all of them are going and when the short happens, they all lose power and just go into limbo on startup? But wouldn't they remember their last taught state after a power up?
I have been actively trying to troubleshoot this issue, but wanted to see if anyone had any past experiences with this?
Thank you
KARIN
If you wanted to factory reset or teach them, how do you do it? Is it possible they are getting this signal erroneously?
Hi Everybody, I Have an issue with IFM 02d224 camera. the camera communicate with contrologix PLC by ethernet. there are two applications in the...
129
Hello, I am new to Codesys, and am trying to learn about it for a project we're developing. I've got a couple questions, but first a little...
228
How can I integrate my S7-300 Simatic with the IFM AS-i Master AC1335 and its slave IOs, such as 2411 and Airbox 2041, into Simatic Manager?
165
When adding an IFM AL1322 IO-Link Master Module to a 1756-EN2T Ethernet Card on a 1756-L82E Controller, The Input and Output data file does not...
113
Hello, I have downloaded the IFM AL1327 .eds file and went through the EDS Hardware Installation process on Studio 5000 v32. It seems to work...
1,076
