JustAnotherBitBanger
When adding an IFM AL1322 IO-Link Master Module to a 1756-EN2T Ethernet Card on a 1756-L82E Controller, The Input and Output data file does not have an array called 'Data'. Instead it contains individual tags named Input_Data1 , Input_Data2 etc... of type UINT.
When I add it to a 1769-L30ER Compact Logix Controller, I get an array tag named 'Data' as expected in the input file.
The Input_Data1 format won't work with AOI from IFM. How can I get the module to produce the 'Data' Array on the L82E Controller?
See pic showing the side by side difference of the input data structure of the two different controllers.
