Allen Bradley Panelview Plus Compact 600 HMI problem
PakEngineer
Mar 2018
Karachi, Pakistan
Above mentioned HMI is installed in my plant with Micrologix PLC. Yesterday the HMI suddenly stopped working during plant operation and HMI's screen goes "Blank" with backlight ON but no text and display. I tried to reset power of HMI but nothing happened. Now whenever i apply power (24 VDC) to HMI, it starts with "Blank" screen with only backlight ON but no text and display even no startup Allen Bradley logo. I dont know what's the problem with HMI and what caused this problem. HMI has given only 2 inputs; a 24 VDC power supply and communication with PLC via serial (RS232).
At startup COMM (Green) and FAULT (Red) LEDs blink for few times and then both turns OFF and thats how this HMI normally starts according to its technical manual. If any Hardware or Firmware fault occurs, one of these two LEDs should keep blinking but since they both turns off it means HMI is starting and loading normally but display does not come up.
I want some help in this regard on how to resolve this issue. Would the problem be resolved if I remove the battery and re-install it? Or if anyone have any other solution please specify.
Thanks in advance
Sorry i didn't mention it earlier, I disconnected the HMI from PLC and brought it to my workshop for checking. That's why COMM LED is OFF. But still HMI should have display on startup.
I have another HMIs that can start and load their installed programs without connection with PLC and they just won't show parameter values.
Hi Having issues with a older PanelView touch not working. Screen is connected to a Desktop computer. screen used as a display with touch...
133
Hello brothers We are contacting you because an error like [display change is currently controlled remotely] occurred while using the equipment we...
238
Every time I power this unit up it loses its IP address and goes to DHCP . When I goto the config the IP address is 0.0.0.0
750
Hello, I have several SLC-500 based systems. The user interfaces are PanelView 2711-TC1 touchscreens with firmware revision 3. I purchased a...
2,096
i was trying to run a .mer file which i have uploaded from a running pvp1000 same model. when i load it on new pvp1000 it shows " the terminal can...
2,270
