How should I fix my alarm display screen?
junke715
Jan 2020
US
21
Hello guys,
I just started my first project with factorytalk view studio, and ran into a problem, if guys have any suggestions please help me.
so here is,
I have the alarm screen pop up whenever I got alarm, and I have momentary push button on screen that connected to my plc using remote acknowledge tag, and display setting is replace the screen. but if I acknowledge the alarm, the alarm screen will go away and show all grey on screen. because its replace the previous screen and nothing is under it.
how should I go about it when I acknowledge but still stay in alarm screen?
Thank you
The [ALARM] is the default alarm pop up. It is an On Top type display. If you created you own alarm screen it should not be a replace type display. If you use a replace display you must open a new replace type display. It sounds like you only need to change you alarm screen to On Top.
Thank you for the help.
That's what I had before, but my goto display buttons wont work when screen is On top, I had to switch to replace in order for goto display buttons to work. any ideas why?
No, something is messed up. Having an on-top display, alarm or otherwise shouldn't change anything with your goto display buttons.
I am not sure how your opening your "alarm" display. It seems that you have created your own and are not using the DEFAULT display [ALARM]. I just tested a GOTO button on the default [ALARM] pop-up and it worked. It opened the display under the alarm popup. The [ALARM] display comes with the Can Not Be Replaced option box already checked. This only means you can not replace it with another On Top Display without closing it first. So, I am not sure I fully understand your issue.
Yes sir, I did created my own alarm page, because I didn't like the banner. but how should I fix button issune on my own alarm page?
Why not just change the default [ALARM] screen to whatever display you want? Delete the banner and use your own.
Under objects > Advanced > Alarm there is an acknowledge button if you use this button it will auto close the display used in the Alarm Setup folder. If you have created a custom alarm screen then replace the [ALARM] display in the alarm setup folder with your custom display. Make your custom display an On Top display (can not be replaced). This should close the display when the acknowledge button from the advanced objects is used. This will leave the original display open.
If your custom display is a replace display then your GOTO buttons on that display should work. I don't think a remote ACK button will auto close the replace display. I tried that this morning with the Default display and could not get the alarm screen pop up to close using the remote ACK.
If your using Global Connections remote display tags to open the Alarm Display then you must return the global connection to zero to allow HMI navigation button to work. I doubt this is the case because you haven't mentioned any diagnostics display opening showing errors or warnings.
If this is the case then you'll need to create a Macro to open your next screen when you close the alarm display. For this option each display must have a unique number setup under Display Settings. Then place your macro on the Behavior tab for close screen.
Macros follow: form=expression So: Global Remote Display tag = next page unique number.
Thank you everyone for helping out.
I got it figure out, there is an internal setting on my panel view that closes alarm screen after acknowledged them. now it all worked out. I will keep all you solution in mind in case next time different things happen.
thanks again, I appreciated all your help
Hi, We are upgrading from fix32 to Ifix. We will be using SQL Server to hold and retrieve our alarm and Event data. 1.Can we also use SQL to...
4,128
Hello All, Please direct me to post to the right page. I am really new to PLC, and want to find a tutor who is familiar with Automation Direct's...
455
Hi, I am working on automating an industrial fabric shrinkage tester to replace its outdated electronics with a PLC. To get the tank's water level...
17
777
In a control System, I need to move 3 motors attached to roller in stages with speed of 1 to 2 RPM and the torque of motor should be 8-10 Nm...
839
Hi, I want to build a production line project using a PLC. This is the project page...
2,260
