1768-L43 Questions
d21x
Jul 2008
Illinois
30
Using a 1768-L43, can I use two 1768-ENBT's and one 1768-M04SE Module? Reason for using two ENBT's is one is for communications to Panelview, RFID and for PC connection. The second ENBT would be use for data collection connecting to the network. Please let me know. Thanks.
I used an L43 recently and according to Rockwell and the manuals, you can only use up to 2 communication cards to the left on the 1768 bus.
I just tried adding more than 2 cards in Logix and it will not let me either.
David
One 1768-ENBT module will provide both I/O, programming, and data collection services. Just make sure you provide a switch that can do IGMP snooping and querying to constrain the multicast generated by the I/O connections.
If you need a different IP address for your data collection system, use a local router with TCP Port 44818 forwarded to the 1768-ENBT.
David
It is a fact, only 2 modules to the left, ENBT and SERCOS (I've used the configurations quite a few times myself, pretty sweet system for the money)
Your issues are solved though.
Take KenR's advice, he's an AB guru and has answerd a lot of questions on this forum.
Best of all, his services are free of charge and always right on the money!
Only reason I want to use two ENBT's is because I don't want corporate to have to assign IP addresses to each device on the network. I also don't want to deal with having a managed switch.
Because I am using the L43, is it possible to use a 1761-NET-ENI for data collection?
Apparently, they are not compatible and i was hoping there was a work around.
699
Good day all. I'm trying to create a new project with a 1668-L43 CompactLogix controller. When I try to create new, That controller is not in the...
1,913
Absolute newby here. Also new to PLC. But I am a seasoned Electronics and Computer Tech. Helping to get my buddy's machine back up and running...
2,175
I have a question concerning network connectivity to a Compact Logix 5343 1768-L43 processor. Some background information: 1) The 1768 PLC...
1,670
Hey all. Perhaps a distributor question but some opinion never hurt. I use a ton of L43 and L45 processors. Many already installed and still...
2,197
