Unity pro convert IL to FBD
Werner
Apr 2005
IJsselstein
336
Is theire a way to convert an IL program to an FBD view program within Unity Pro XL? (This is possible with Siemens Step 7)
The FBD view looks like a visio technical drawing. So to convert IL to FBD will create some problems with the location of the blocks....
No its not possible
And its only possible in S7 because all the code in an S7 is in IL and the FB and Ladder versions are only representations (where possible) of the IL. As you noted in Unity the function block program is a complete separate langauge allowing multiple function blocks to be interconnected forming a complete as you say 'technical drawing'
Thank you!
I noticed the quantum plc's have special I/O addressing method like:
%I1.2.3 (Rack 1, slot 2, channel 3).
I also noticed that "flat addressing", like %i0001, is also possible? But where can you make the selection for the addressing mode?
Hi Everyone, Is it possible to convert a PL7 4.5 .stx file to Unity Pro. Also can this be done without the PL7 software, I have the .stx file...
5,982
Hello, I am using Unity pro V15. I have Quantum CPU 671 and Ethernet NOE 77101 configured. I have configured IO scanning on NOE. I have attached...
175
HELLO MY FRİENDS ı have problem. ı tought you can solved thıs problem for me. First of all When I checked all the cable connections of the...
402
Hi All, I haven't installed Unity Pro in years and needed to install it recently. I initially tried installing Version 11.1 and the whole...
709
Hello i want to implement a Read_var / Write_var functions to communicate with a modbus tcp device at the moment i use the unity simulator at the...
1,925
