Mitsubishi PLC - Ext Base not detect
zai_jnr
May 2008
MALAYSIA
169
Hi all,
I'm now working with Mitsubishi PLC which is configuration is :
1) Q02CPU - CPU
2) Q61P - Power supply
3) QC06B -i ) Extension base cable from mainbase to ext base 1
ii) Extension base cable from ext base 1 to extbase 2
2)Q38B - Main base
3)Q55B - Extension base 1
4)Q55B - Extension base 2
I've got trouble when ext base 2 cannot detect by CPU. When try to trigger signal from ext base 2...signal also will trigger signal at ext base 1..it seem like address at ext base 2 was overlap with address ext base 1..
actually I'm already setting all the start X/Y at PLC parameter setting for I/O assignment. But result still not good.
Parameter setting I/O start X/Y is as below :
main base
0000 - 32 i/o
0020 - 32 i/o
0040 - 32 i/o
0060 - 32 i/o
0080 - 32 i/o
00A0 - 32 i/o
00C0 - 32 i/o
00E0 - 32 i/o
extension base 1
0100 - 16 i/o
0110 - 16 i/o
0120 - 16 i/o
0130 - 16 i/o
0140 - 32 i/o
extension base 2 (not detect by CPU)
0160 - 32 i/o
0180 - 32 i/o
01A0 - 32 i/o
01C0 - 32 i/o
01E0 - 32 i/o
so what i need to do?:( any idea really appreciate...
126
I have Toyopuc PLC PC10G-CPU and some communication modules of it. With this modules I'm able to connect with Ethernet, Ethernet/IP, FLnet, FRMT...
89
Hi all, anyone does have experience in Gx Works 2? Currently I having an issue which is when certain device added from MELSOFT Navigator and...
113
Hi All, I am after some assistance setting up kepware to take tag data from an FX5U PLC, I have tried many many port numbers and still cant get a...
158
