1769-AENTR Web Login
Macly
Mar 2017
Milton
Hi everyone,
I am trying to set the IP addresses in a 1769-AENTR module through its web page.
Does anyone know what the login info is?
Thank you very much
http://www.plctalk.net/qanda/showthread.php?t=75298
http://www.plctalk.net/qanda/showthread.php?t=90048
"Another method, if all else fails, is to use the adapters web page. Set the address switches to something like 20 and power cycle. The IP address should now be 192.168.1.20, Subnet 255.255.255.0. Set your PC to 192.168.1.10 and 255.255.255.0, or similar. Ping the adapter to check you can "see it". Open a web browser and navigate to the adapter IP address. Login with user: "administrator", password: "blank". Under "Network Configuration" configure the adapter for Static and set your new IP address and Subnet. Apply changes. Change address switches away from 20 to above 254 (not 888 or 999). Power cycle and the new address should be active. "
The above threads should help you out.
Regards,
Regards,
Thanks for the reply. This information is for 1747-AENTR. Apparently the login info for 1769-AENTR is different. I have tried "administrator/blank" and it didn't work.
Thanks guys for the help. I contacted Rockwell support and apparently it is username "administrator" and password "the serial number shown on the webpage".
Hi everyone, I recently put in a 1769-AENTR, and where it is installed has had a couple power outages. Every time when the PLC comes back online...
705
Dear All, If you could please help me with the following issue it would be very helpful. Trying to solve this for the last week. I've a L33ERM...
1,260
Is anyone else watching AB 1769 1794 1734 pricing on ebay, or am i the only one??? 1769 AENTR for $4,000.........From China........Its getting...
2,057
3x 1769-AENTR being polled by 5069-L330ER PLC. AENT modules are freezing approx once per day each. Loss of communications from perspective of...
1,706
Hello everyone, I am in the beta phase of building a SCADA system. Currently planning to use Inductive Automation as our SCADA platform, but...
2,174
