Mitsubishi Battery
marc81
Feb 2005
I'm having problems finding somebody who stocks mitsubishi plc batteries, the only one i've found in the uk is mds who have got the battery i need on back order and have done for some time.
The battery I need is type A6BAT also found as B9670MC for an A2 PLC.
Any help much appreciated.
If you are really desperate and can solder, you could consider transferring the lead on the original battery to a half AA 3.6V lithium battery (ideally one with solder tags). You should find these available from numerous outlets. My best guess (please check) would be that you need to keep the plc powered while you change the battery. Better still, ensure you have a backup of the program first.
Regards,
LC Automation (Mitsi PLC Battery)
Try LC Automation, have never let me down as yet regarding Mitsubishi gear.
Regards, Gene.
Try Here for Mitsibushi batteries
http://www.mdsbattery.co.uk/departm...DepartmentName=PLC+Batteries&DepartmentID=180
Your particular one with the leads all ready to plug into an A2 is here i think
http://www.mdsbattery.co.uk/shop/productprofile.asp?ProductGroupID=1456
Just £14.10 including VAT
I have used them for AB and other Batteries and can recommend them 100%
They are a US Firm based in the UK and are very helpful
They List the following plc's
Allen Bradley
Cutler Hammer
GE Fanuc
Le Blonde
Mitsubishi
Modicon
Omron
Siemens
Texas Instruments
Hope this is of help
Cheers
Dave
Hello Everyone, I have a Mitsubishi PLC FX3U According to Mitsubishi PLC manual we have to power off the plc and change the battery in 20...
1,782
I remove the battery from mitsubishi fx 3u 80mr plc...now error led is flickering. I try to upload the program by gx work 2 software but it not...
2,131
I unplug the battery from mitsubishi fx 3u 80mr plc...now error led is flickering. I try to upload the program by gx work 2 software but it not...
1,426
I'm translating a program from RSLogix500 to Mitsubishi Q type plc, using Melsoft GX, and I just need to know which vales of Counters, Timers and...
2,295
Have a new machine installed with Q series PLC. Battery light was flashing so I pulled the battery which had not been connected. Connected...
3,944
