TIA Portal online monitorring without offline project
userxyz
May 2002
any
2,768
Did you guys know that you can see the program online without having it offline ? You can go via the menu -> Online -> Accesible nodes and then select the CPU and click on show. It will actually give you the program that is inside the CPU.
However, monitorring is not possible... I think u must do an upload before monitorring is possible ?
Kind regards,
Gerry
In the old Simatic Step7, if you knew the address and slot where the processor was installed, you would upload the program first and then you could go online. Although no comments would be available which kinda defeated the purpose of monitoring online.
I know that at least on V11, uploading was a chore on TIA Portal, but haven't played with this on the latest versions. I also heard here somewhere that the upload will contain the comments (or potentially is an option of the programmer).
[Warning: much griping follows]
Unfortunately, uploading is still a pain. It's hypothetically possible, most of the time, unless it isn't.
In the cases where it does work, there are a few different ways it feels to me like you should be able to do it, but it isn't any of them, it's some other way that I can never remember. And I think you have to be offline to upload?
The big gotcha for me is safety. You can only upload safety projects starting at V14 SP1, and only if the option is enabled in the safety settings, and only for 1500s. If you DO enable the setting, it triples the size of the load memory of your project.
105
Tia portal v18 issue,online icon greyed out but plc comms must be established as.blocks showing and no offline copy on laptop.
1,127
Hello, i can find the CPU when searching for it. But when I go Online i just get the icon for "Not compatible" everywhere. I get no additional...
1,254
Hi I have a machine that has 1500 cpu program is v15:1 I have the program from the Oem and the tia portal software v15.1 ? I have set the laptop...
1,889
Hello all. I have trouble getting online with TIA portal V15.1 with a VIPA CPU(VIPA 315-4PN12). If I try to connect I get an error message that I...
3,392
