Studio 5000 revision issue
Scotty13
Jan 2016
Chicago, IL
Hello!
I have an issue with my Studio 5000. I have installed Studio 5000 with rev 19. But my PLC has rev 21.**. How I can install prev revisions of PLC firmware into my studio 5000?
You need to install Studio 5000 V21.xx on your computer as well. Major revision in the PLC and computer has to match. Furthermore, there are some issues with V21 to watch out for
You need Rev 21 to upload the program, or open a copy you have as 21, to downgrade to 19. You can get 21 from the RA website for free if you have TechConnect. You can get prior versions (e.g. 18) from the same site without TechConnect.
Of course, if the PLC has no program but flashed to 21, you can just wipe it and flash it as 19 so your laptop will work. Flashing erases the program. Firmware files are on the RA site and search the forum for instructions on how to do it.
Sorry I missed. I have installed S5k with R21 and PLC with R19. I everything will be ok if I'll install oldest rev S5k over my R21?
Yes, it will be okay. You can have multiple major revisions installed at the same time. So when you install 19 it will still have 21 on it as well and you'll be able to open projects that are in either version.
I have 21.03. The problem that I cant find out Logic Designer on AB website. I gave a call to tech support but they offer my to download Logic Architect o_O .I can't understand what the reason from Architect when I do not have right version in Designer.
Scotty13, Someone else correct me if I am wrong but I believe I ran into a devastating issue with that exact rev.
21.03 is a security resilient version which what that means to you is that you need the original copy of the program on that controller for you to be able to connect to the controller and make changes. There is a SUPER painful way to get that program off of the controller that I have found but I could not walk you through that disaster.
also, I deal with various versions of programs in the oil field, V21.03 messes with alot of my other versions and our company has removed 21 from anything we deal with because of such. I dont remember all of the technical stuff behind it all but I would recommend removing 21.03 entirely from you computer then reinstalling 19.
someone here I am sure has better knowledge of the dreaded v21.03 but I do know that it has caused our company and others a world of hurt. And I know rockwell removed it and had some sort of falling out with that rev. If you need 21.03 and have a licences for it I think I have the program files for it here somewhere, just let me know.
Hi guys. I'm trying to display the controller firmware revision number OR the logix designer version number on my panelview plus 6 HMI. So I think...
1,795
Good Afternoon , I have a Studio 5000 project that I would like to change from version 29 to version 28. I know how to use ControlFlash ...
2,354
Hello, I am trying to connect to a CompactLogix L24ER QB1B with a rs5000 image that I've never connected to before. The problem is that when I...
3,064
So say i wrote a program im studio 31 and i hand it to a customer that has a cpu with firmware 30 Can the program be rolled back? I know for a...
16
4,562
Hi all, I have just purchased the software for studio 5000 with just the option to down load via the internet (no cd/thumbdrive) I have downloaded...
1,884
