Nema 4 bulkhead connector?
Zlinger
Mar 2014
AZ
36
I have to pass some poly tube through the side of a control panel and maintain a Nema 4 rating. I have used bulkhead connectors many times before without having to worry about weatherproofing. It doesn't seem that any bulkhead connectors I have found are Nema 4. Anyone know of any? I have looked at Roxtec's stuff, but I am hoping to find a normal bulkhead connector with a gasket. Any help is greatly appreciated.
Does it need to be NEMA rated for UL or code reasons, or are you just trying to make sure that no water enters the enclosure?
If the latter, going through the bottom of the enclosure is pretty foolproof.
Do a search for the term "CGB connector", it's an old designation for a cord connector with a rubber compression seal originally made by Crouse Hinds (who is now part of Cooper / Bussman, who is not part of Eaton...) Over the years, CGB became a common industry term and a search for it will link you to pretty much all of the major suppliers now.
The difference between this and a Roxtec seal is that with Roxtec, you can get one seal for multiple cables / tubes etc., with CGBs it's one connector for one cable/tube (for the most part). Roxtec seals are also fire stops and rated for marine bulkheads (meaning pressure tight), that's why they are so much more expensive. But if you don't need all of that, they are often budget busters.
If jraef’s solution is something you would use, a current part number is a Thomas & Betts 2522 which has a 1/2” NPT thread and the rubber grommet with approx a 3/8” opening. If NEMA 4 is required, you can use a sealing ring T&B part 5302.
I have noticed that many HMI have a Nema rating of Mena 4/4X (indoor use only) Does anyone have any guesses as to what the constraints are that...
1,823
Looking for some explanation/history between North American electrical symbols standards (how they relate, what are the latest, what is the...
1,732
Good evening gentlemen, I am looking for VFD with NEMA 4x rating. It's a small one, single phase 208/230 input, 208 three phase motor 8.46 Amps...
3,490
Hello, are there any standards for control wires naming rules? I have to set them up in my project (see pic). What is usually prefix and...
2,254
Looking for a brief explanation for the NEMA MG-1 Part 31 standard for the actual voltage values. In reading many articles I have seen 1488Vp...
1,419
