RSLogix 500 Version 10 Crashes when closing
OkiePC
Mar 2005
ENE of Nowhere Oklahoma
11,791
I am running Windows 7 Pro 64 bit on a Dell Latitude laptop. Every time I close an instance of RSLogix 500 I get a pop-up:
RSLOGIX 500 DEVELOPMENT ENVIRONMENT HAS STOPPED WORKING
VERSION 10.00.00
Problem signature:
Problem Event Name: BEX
Application Name: Rs500.exe
Application Version: 10.0.0.0
Application Timestamp: 563b0b7a
Fault Module Name: MSVCR90.dll_unloaded
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 4dace5b9
Exception Offset: 7389cf5e
Exception Code: c0000005
Exception Data: 00000008
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1033
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
It seems to work fine and save files fine, and I usually have multiple instances running which scared me at first because I was unsure if the instance I had working with online edits had crashed or the instance I had just shut down.
You guys can probably help me find the answer quicker than searching the knowledgebase.
Thanks in advance!
Paul
I am running RSLinx Classic Lite version 3.71.00
More info:
It only happens if I have more than one instance open. I just did this without ever opening a file, just two instances of RSLogix 500 opened at the same time. I close one of them and get the error. Closing the other instance did not generate an error. RSLinx is not running when this happens.
I have the same thing happen if I close a window of Internet Explorer with more open.
But in this instance it causes the open windows to reload their pages and they show a warning that 'a problem with this webpage cause IE to close and reload the page'
Have you tried to do a repair of the installation from the control panel > programs and features?
james
No. I have just been clicking "Close the program" each time it happens, although the program appears to already be closed. Now that I know it is not causing any real functional problems, I have not aggressively tried to solve it.
As soon as I am caught up I will drill into it...right after I clean and organize my truck, get a hair cut, finish the tile in my bathroom...all those things I am planning to do as soon as I am caught up...
I have received a project of converting an existing SLC 500 program to a Productivity 3000 program. My question is there a tool to help achieve...
726
Hello All, Using a Micro1400 thanks to its DNP3 capability. DNP3 spec requires syncing PLC to a UTC source. However, my local HMI needs to be...
838
I have came across some Allen Bradley SLC processors with no backups running version 3 firmware. Does anyone have software that old or a...
2,718
Hello All... I am programming a Micrologix 1400 series C and cannot "Save" online edits. I can perform online edits, but when I try and save...
2,259
I have a Micrologix 1400 controller that has a Rslogix 500 V9.0 program in it. I am needing to make a program change to this controller, but my...
6,296
