1747-SDNPT Driver not in list of available drivers
DC1
Jan 2006
Brownwood, TX
Does anyone know why 1747-SDNPT does not show up in my list of available drivers when I try to choose a DeviceNet driver in RSLinx? I am running version 2.54 RSLinx Classic Gateway. Any help will be appreciated. I have tried to find it as a download from AB with no success.
It should be there, I have used it on several versions of RSLinx going back a ways. It should be about 2/3 of the way down and is described as DeviceNet Drivers (1784-PCD/PCIDS.......)
Stu....
Do you have another driver already configured that you'll use as the path to the SLC that hosts the 1747-SDN ? I know that's a precondition to creating the 1747-SDNPT driver.
Do the usual deletion of the Harmony.rsh and Harmony.hrc files in the RSCOMMON folder, which is often done to clear out configuration corruptions in RSLinx Classic.
Hi all I am working with a SLC 5/02 and having trouble getting online with it. I am using a 1747-UIC adaptor which allows for USB>serial and...
124
I have a slc500 plc 1747-L30A. Using a communication cable 1747-PIC cable box combination. Running a version of software from DOS on a Windows 3.1...
172
hello I am getting a 57h fault - Specialty I/O module has not responded to a lock shared memory command within the required limit. Fault randomly...
120
We are in the process of upgrading a controls system. The existing system is a SLC500 with some IO cards and a 1747-SDN module communicating to a...
569
se me desprendieron los cables del cable usb quiero soldarlos pero no se como van los cables si alquien me pudiera proporcionar una foto o como...
416
