Simatic Op7 Error
BoSChoW
Apr 2006
Nova Gorica
107
Hey all , i finished an display program in ProTool and after i downloaded it to the OP7 an error appeared that it states:
$551 AS address 2 not possible. Does anyone know what does this mean?
All help will be aprishiated. Thanks again.
Baudrate you set is 12Mb/s?. You use Op7DP or Op7 DP12?.
Can problem with baudrate if you use OP7/DP
It means that there is no communication to address #2. Are you connecting the OP to the PLC with a profibus cable or a MPI cable into the PLC port on the display and not the serial port. I am assuming you configured the OP as a S7 device and not a S5.
From memory, you press ESC + Right Arrow + Down Arrow at the same time at Start up(Power up) of the panel. I think this wipes the unit and places it into transfer mode.
Hope this helps!
Yes it works, thank you man. Unfortunaly, i have an another question. I have a screen that looks like this:
Input01: 0
Input02: 0
Input03: 0
Input04: 0
I want to transfer the state of the input to the plc, any ideas how do i do this. I already tryed with selecting a function botton to do a transfer from OP to PLC but it said transfer locked, then i inserted an recipe and now is saing task invalid. What should i do?
Are you using a PLC JOB for your Data transfer? i had a similar message when using Job 51(force screen) because i wasnt sending the job number in Hex.
Please provide more detail or even post your program.
I defined in the protool that the F2 function botton will transfer the data from the op to the PLC, do i have to write a program in the function block to make the transfer possible?
Hi, where can i find information about error's of the Simatic OP7? I get the following error: $044 Transerror no. 8 What could this mean...
3,854
Hi, does anybody know, what means error message on simatic OP7: "$551 AS address 2 not possible"? I've got this message after downloading a...
12,472
Hi all! I have this old Siemens Simatic op7 panel I need to rescue. At boot nothing appears on lcd, backligth and all led's are on. Does not...
795
Hello everybody, I am actually trying to bring an old machine back to life. It is set up by a Simatic S5 CPU (95U) and a Simatic OP7. The old OP7...
2,633
Hi, I'm new to Siemens Simatic OP7 HMI. I have an existing Siemens Simatic OP7 HMI, I want to store data of HMI in a database or excel file. Is...
3,619
