script
May 2018
london
20
please help me to read this script.
also suggest me the link where i can learn script
IF lifting_mov3_p = true
THEN
destination_tank3 := 10;
process_number3 := 1;
END_IF;
IF tanknumber3 = destination_tank3 and bottom_limit3_n = true and phosphating_only = false and process_number3 = 1
THEN destination_tank3 :=11;
process_number3 := process_number3+1;
END_IF;
IF tanknumber3 = destination_tank3 and bottom_limit3_n = true and phosphating_only = true and process_number3 = 1
THEN destination_tank3 :=15;
process_number3 := 10;
END_IF;
IF tanknumber3 = destination_tank3 and bottom_limit3_p = true and process_number3 = 2
THEN destination_tank3 :=12;
END_IF;
IF tanknumber3 = destination_tank3 and bottom_limit3_n = true and process_number3 = 3
THEN destination_tank3 :=13;
END_IF;
IF tanknumber3 = destination_tank3 and bottom_limit3_p = true and process_number3 = 4
END_IF;
IF tanknumber3 = destination_tank3 and bottom_limit3_n = true and process_number3 = 5
THEN destination_tank3 :=14;
END_IF;
IF tanknumber3 = destination_tank3 and bottom_limit3_p = true and process_number3 = 6
END_IF;
IF tanknumber3 = destination_tank3 and bottom_limit3_n = true and process_number3 = 7
END_IF;
IF tanknumber3 = destination_tank3 and bottom_limit3_p = true and process_number3 = 8
END_IF;
IF tanknumber3 = destination_tank3 and bottom_limit3_n = true and process_number3 = 9
END_IF;
IF tanknumber3 = destination_tank3 and bottom_limit3_p = true and process_number3 = 10
THEN destination_tank3 :=10;
END_IF;
That script seems to configure a sequence for tank filling in the PLC.
This seems pretty easy to understand... if you want to know special functions available, that will depend on your SCADA package.
Hello. I have a db which is 1000 INT, and this db is represented in WinCC as a raw data type set of 5x 400 Bytes. This set is read with a script...
94
Hello Experts I am working on a project with WinCC Unified v16 PC system and want to create an option on the screen to export logs to the...
77
Hello, I am learning to create shapes and VB Scripts in HMIWeb Display Builder. I wanted to change color of my rounded rectangle by script. I...
124
Hello, I have a quick question. I have been using scripts to change the color of buttons. The reason, I am usually using multiple hmiruntime.tags...
129
Hi All, I'm keep getting double quotes in between selections rather than the beginning and the end. Here's the script and please help to find...
827
