LG master-K series PLC-using RS232
mvitale42
Oct 2009
michigan
Can't Communicate using RS232.
I finally got the english version of the tech manual for LG. I've followed the instructions step by step. i still get the error "failed to Connect to PLC". I'm using a standard RS232 comm cable. can anyone help!!!!!!!!!!!!!
Hello
I'm in the same trouble and I need the same information. Also, can tell me how did you get the english version of the manual ?
Hello,
I can. I have one (KPS-7AS) sitting here and it works fine.
It depends on what you are trying to do. The port on the CPU has two functions, a 'loader' port and a 232 port.
K200SOPERATORMANUAL.pdf -- "Please refer chapter 13.3 for detail pin-out of RS-232C connector."
Or does this not help?
Good luck,
Mark
http://www.peakhmi.com/
can anyone help me please?
Master K using standard RS232
If using Standard USB to RS232, just switch or swap pin 2 and pin 3 (Tx & Rx) to make it RS232C(cross).
Tx from programmer to Rx terminal in Master K CPU terminal.
Rx from programmer to Tx terminal in Master K CPU terminal.
Error "failed to Connect to PLC" SOLVED(y)
This is an old plant with series 6 systems, running via Logicmaster 6 parallel software. Our workmaster went down and we need parallel software.
2,701
Is it possible to configure an Allen Bradley panelview 1000 series to be a modbus RS485 slave? I guess I am not certain exactly how/if that would...
3,643
Hi, let's see if someone can help me here. It's the first time I work with a GE FANUC PLC. The client gave me the backup files they took from the...
7,129
-Channel 0 as the modbus master port -8 slaves (Yaskawa VFD's) on a RS-485 multi-drop network -I can talk to the slaves (Yaskawa VFD's) through MD...
9,851
Hi, I am looking for the program that was avaialable for the GE Micro Series 90 plc - called Logic Master 90 but i need it to run on the Windows...
4,264
