Allen Bradley Micro850 - Not Reading Inputs, Not Enabling Outputs?
cschwartzman
Dec 2017
**** Off
Hey folks!
Bumping into the most basic and annoying of problems. My Micro850 isn't reading inputs and it isn't enabling outputs. I used a jumper wire from the +24v power terminal to _IO_EM_DI_00 and, while the power light and the RUN light is lit up, the corresponding input led doesn't turn on.
My program, such as it is, consists of a normally open contact (_IO_EM_DI_00) in series with a single coil (_IO_EM_DO_00), which was built and uploaded to the PLC before testing.
Ideas? Tutorials? Is it possible the PLC is ****ed up? Is there a factory reset option somewhere that I can't see?
Help, please :/
Hello all, hope your week is going well. I am currently working on debugging a Micro850 with Category number 2080-LC50-24QWB. When I connect...
2,382
Hi, Iam Working in a project where Micro850 and Epson ROBOT is there, I need to read and write bits to and from ROBOT. Iam Using TCP/IP and...
1,279
I'm having major issues programming the high speed counter function on the Micro 850. I have no more avenues to pursue... I've tried everything I...
8,561
in allen bradley kinetix 300 drive first E31 error shows after resting drive E11 error occurs need solution to reset E11 fault code
144
420
