PACSystem Rx3i Time and Date
mikewest
Oct 2013
Drifting
I must have missed something in the manuals / online help but I can't figure out how to change the Controller time and date on a GE PACSystems Rx3i controller that I have inherited the maintenance and support of.
I have read something about syncing to a time server but this baby has no external connection and it has a date set for September 2000 which is just slightly wrong. I don't need the time to be really accurate as it is only for internal diagnostics. It has thrown a couple of faults over the last couple of months and it is a pain to try and calculate back to the actual fault generation time. TBH this is one of the lesser problems I am having with the this whole system but it is really bugging me.
I hope someone can point me in the right direction.
Go online with the controller.
Right-click on the controller, then click on "Show Status".
In the new window, click the Date tab.
You can sync to your PC or set a time manually.
Hi I'm doing a boring manual conversion of a ladder program and have a question regarding how the timers work on this system. I don't have this...
2,448
Hello All- I'm trying to re-structure my PLC code (in LD). The current code has blocks contain different type of memory areas (%AI, %AQ, %I, %M...
2,471
A question to those unfortunate souls that have had to work with GE Fanuc PLCs... I'm using an RX3i. How can I get the time from the PLC? I...
3,158
I have a system using Rx3I CRU320 redundant CPU with Proficy Machine Edition Software. In the hardware configuration of each CPU module, under...
426
Hi, we are using Rx3i CRU320 redundant PLC system and we noticed a discrepancy between Primary and Secondary controller. Couple of variables (DI)...
321
