Fanuc robot with a Quickpanel HMI
Robodude
Sep 2010
Colorado
16
I have a Fanuc R-30iA robot controller. I am using a GE quick panel for a HMI / operators panel. How do I define the robot I/O I would like to read and write in the quick panel. It seems like you define the signals as variables in the quickpanel. To start simple, I would like to put a program start and program stop button on the screen that would turn green based on if the program is running or not. It seems like you would use color animation for this and declare a input as a variable. Is this correct and how do you tie the variable to the robot IO?
What type of plc are you using to communicate between robot controller and quick panel. Have you ready configured robot UOP setting?
I am hooking the GE quickpanel directly to the robot via ethernet. I am not using a plc. I have not configured UOP yet. Will this set the IO up to be read by the quickpanel?
Never seen a additional HMI connected this way. How would,never mind. I guess if there is a will there is a way. I will have to research this as well. Do you have manuals and fanuc tech support?
The robot is set up with SNPX or SRTP. I do not have the quick panel hardware yet. I have the proficy software I am starting to program the HMI with. I will have the robot and the GE quick panel in 2 to 3 weeks.
I have a manual on the robot and quick panel unit. I do not have the robot yet so I don't have a F# for fanuc support.
I never met a Robot who talked SNPx or SRTP, all that I have seen are setup for EGD (Ethernet Global Data) or Genius (GE Proprietary highs peed Serial). At least it is simple to change the QP's variables from one protocol to another so any development is not lost.
I know this thread is two years old.
I am attempting to duplicate this situation of using a Quickpanel View with an R-30iA.
How do I get the variables from the Quickpanel to manipulate I/O on the Fanuc robot via Ethernet. What protocol do I need to use for this to work properly.
Did you read the old posts?
What Ethernet Protocol(s) are on the Robot that match what is in the QP View?
Look in the "PLC Access Driver" area under "View OPC Drivers" to find what is available on the HMI. I recommend staying away from the "Native" drivers.
I have hooked up a GE quickpanel to the R30iA controller a couple of years ago. The option in the robot you need is SNPX / HMI ConnectionYou will then be able to communicate with the quickpanel via ethernet. Do you have the GE proficy software to build your interface on the quickpanel?
It also doesn't help that I don't really know the Fanuc robots either.
Is there a way to check what options are installed?
And yes I have the software, Version 7.0.
SNPX in the GEIP world is a serial protocol, not Ethernet.
Has anyone setup communications from a GE quickpanel to a Fanuc robot (R2000)? I know I have to setup the plc as a GE SNPX. The part I was...
4,527
Has anybody setup a connection to a Fanuc (R2000) robot? I've got an existing application that I need to add some functionality to. I just don't...
4,126
Has anyone ever tried to integrate a Raspberry Pi to a Fanuc robot? I have this idea that I want to try out but I need to write integers from a...
1,590
Good Evening , We have had a problem with some broken I/O wires on a Fanuc Robot. I'm sure we just need to rerun some cables , but I was...
1,651
Just wondering if anyone has had any experience with using a Fanuc Robot (R30iB) to a Logix 5000 over Ethernet/IP using Safety. I have some...
1,644
