Fanuc robot Raspberry pi integration
tmadore
Jan 2016
Connecticut
Has anyone ever tried to integrate a Raspberry Pi to a Fanuc robot?
I have this idea that I want to try out but I need to write integers from a Raspi into data registers within the fanuc robot.
I know the fanuc robot has the Ethernet/IP CIP messaging adapter option, but I'm not looking to reinvent the wheel.
Would an OPC solution be easier?
looking for ideas
I don't think R-PIs are reliable enough for industrial applications. My R-PI has died twice. Each time I hand to re-flash ssd.
The big problem is the software for the Ethernet communications.
Writing Ethernet code is a big time sync. It would be best to buy something that already exists.
This is something I've spent a little time exploring, but not on this forum because it's a little embarrassing how little I know about Linux and about "real" computer programming with compilers and repositories and dependencies.
If I had to get a cyclic I/O connection running right away between a Raspberry Pi and a PLC or robot controller that had EtherNet/IP Scanner or Adapter function, I would probably just spend a hundred bucks on a CoDeSys runtime license and a USB key. The ordinary CoDeSys runtime for Raspberry Pi includes both EtherNet/IP Scanner and Adapter functionality.
If I had more skill and experience, I would try to use the OpENer project's open-source EtherNet/IP Adapter.
And if I were participating in a project with a real industrial product as its goal, I would get my software and/or hardware from real experienced vendors like Real-Time Automation, HMS Fieldbus, or Hilscher.
But when reading about something leads me to phrases like "all you have to do is wget the makefile and grep the binaries", I figure I'm in over my head.
As always, disclaimers should apply: you get what you pay for with hobbyist hardware and open-source software.
Earlier Pi's were often described as "unreliable" and that has been many peoples experience. The true culprit in my experience has always been the memory card. I used to buy fairly cheap cards and yes, they would occassionally fail. I started buying more expensive memory cards from Samsung and have not had a sinlge failure since. having said that, Most of my PI4's are now running from an SSD to no memory card involved.
Would I use one for something mission critical? No. I run a PI4 here in the office as a data logging server (amonst other things) and it has been up for 198 days (since last power outage).
If your developing a product to sell then maybe look at something else. Can you make something work? Definately. I have used NodeRed to communicate with Rockwell PLCs and also with OPC servers. You could develope in Nodered on a PI and then migrate it to other hardware if you felt it was necessary.
Exor HMI's also have some awsome abilities to act as a gateway if you wanted something industrial.
Nick
For anyone interested, the attached picture shows part of a flow in NodeRed that is reading OPC data from an Omron PLC in a machine being tested in the factory. The data is then published to an MQTT server. The data is recieved from the MQTT server and logged to a database here and also buy my customer who can monitor the machine on test in realtime.
Nick
Good Evening , We have had a problem with some broken I/O wires on a Fanuc Robot. I'm sure we just need to rerun some cables , but I was...
1,635
Just wondering if anyone has had any experience with using a Fanuc Robot (R30iB) to a Logix 5000 over Ethernet/IP using Safety. I have some...
1,590
I have read every post I can find on how to interface an Automation Direct C-More EA9 series HMI to a FANUC robot with no luck. Some say it is...
3,092
Good morning, I am currently in Nigeria and I came across a problem with a Robot fanuc that is installed in a Huky injection machine. The teach...
1,910
I have a Fanuc Robot F-200iB Series 9, 6 Axis and it is running on R-J3iB controller and the controller is configured to Mitsubishi PLC Q06HCPU...
1,903
