RSLogix 500 (Version 8.4.XX) & Windows 7 64 Bit
burbrink
May 2007
Cincinnati
17
Using Logix 500 (Vers 8.4.XX & Win 7 - 64-Bit) I seem to be having a lot of trouble when performing online editing.
About 50% of the time when I go to assemble edits, Logix simply Fails and throws me Offline.
Any ideas?
Well first of all that version is probably over 10 years old. No way was it designed with Win 7 x64 bit in mind. Could it work? Maybe. Is there a chance to flash the firmware to something more modern? Is this the special redundancy version? What procesor is it?
My apologies. I always misread 500 as 5000! Disregard post!
I don't know if RSLogix500 8.4 has been tested or is compatible with WIN 7 64 Bit. If this is by chance a 5/05 over Ethernet I think it is a RSLinx setting. I will look on the forum because it has been discussed in the past.
Not much of the older software (Logix 500) is officially compatible with Win 7 - 64. It works, not reliabibly.
The configuration is a 5/05 over ethernet, using RSLinx 2.58.
Official Support
Windows 7 (64-bit)
  • RSLogix 5000 v19.00 and greater
  • RSLogix 500 v8.40.00
  • RSLinx Classic v2.57or greater
Windows 7 (32-bit)
  • RSLogix 500 v8.30.01
Windows Vista (32-bit)
  • RSLogix 5000 v17.00 and greater
  • RSLogix 500 v8.00 or greater
  • RSLogix 5 v7.40
  • RSLinx Classic v2.54 or greater
Exceptions
RSLogix 5000
  • RSLogix 5000 software v13 through v18 are now known to operate correctly on Windows 7, if using suggested configuration settings. See the attached document <RSLogix 5000 Enterprise Software Windows 7 Statement.pdf> below for full details.
  • RSLogix 5000 software v10 through v12 are not available for installation on 64-bit operating systems.
RSLogix 5
  • RSLogix 5 v7.40 is known to operate correctly on Windows 7 (32-bit & 64-bit) using RSLinx Classic v2.57 or greater, and UAC disabled.
I have received a project of converting an existing SLC 500 program to a Productivity 3000 program. My question is there a tool to help achieve...
726
Hello All, Using a Micro1400 thanks to its DNP3 capability. DNP3 spec requires syncing PLC to a UTC source. However, my local HMI needs to be...
837
I have came across some Allen Bradley SLC processors with no backups running version 3 firmware. Does anyone have software that old or a...
2,718
Hello All... I am programming a Micrologix 1400 series C and cannot "Save" online edits. I can perform online edits, but when I try and save...
2,258
I am running Windows 7 Pro 64 bit on a Dell Latitude laptop. Every time I close an instance of RSLogix 500 I get a pop-up: RSLOGIX 500...
2,252
