Status Overflow
FSPT_Tech
Jan 2007
Compton, CA
42
I'm trying to understand certain programming functions using RSLogix 500 software. Can someone give me examples of how an S:5/0 (Math Overflow) Status file can be used in a ladder logic andexplain what its suppose to do. I'm not sure I fully understand its function.
Thanks.
Well, it indicates that an overflow has occurred. That can be many things, including a divide by zero somewhere, or multiplying two integers and trying to put the result into an integer (20,000 * 20,000) would overflow an integer.
click here ... if this doesn't answer all of your questions, please post again ... I'll be glad to give it another shot ...
note: the forum went through an upgrade awhile back ... the "attachment" picture is still there - it's just been relocated to the bottom of the post ...
World of Thanks
Thank a lot Ron. You explained everything in an easy and patient manner for all us "beginners". I appreciate sharing your knowledge and advice. I now seem to get a good grasp of the idea of the overflow concept. Your reply helped tremendoulsy. Thanks to you also, rdrast, for your reply. Thanks again fellas and God Bless!
I am working with a remote rack with a 1771-ASB adapter, and inside Logix 5000 I am trying to find where it displays the status of each of the...
78
Hello, I'm working with Studio 5000 and ME Station, and I'm trying to find a way to detect if the PC with the HMI is shut down or not. I've tried...
80
63
Hi all. I have 1793-IE4 (4)analog inputs modules in a 1794-ADN IOFlex DeviceNet Rack. I cannot find if I can I have access to individual channel...
63
I've got a Powerflex 700 that doesn't like to get going in the mornings. This motor will run anywhere from 30 seconds to 5 minutes before it just...
202
