Status Overflow
FSPT_Tech
Jan 2007
Compton, CA
42
I'm trying to understand certain programming functions using RSLogix 500 software. Can someone give me examples of how an S:5/0 (Math Overflow) Status file can be used in a ladder logic andexplain what its suppose to do. I'm not sure I fully understand its function.
Thanks.
Well, it indicates that an overflow has occurred. That can be many things, including a divide by zero somewhere, or multiplying two integers and trying to put the result into an integer (20,000 * 20,000) would overflow an integer.
click here ... if this doesn't answer all of your questions, please post again ... I'll be glad to give it another shot ...
note: the forum went through an upgrade awhile back ... the "attachment" picture is still there - it's just been relocated to the bottom of the post ...
World of Thanks
Thank a lot Ron. You explained everything in an easy and patient manner for all us "beginners". I appreciate sharing your knowledge and advice. I now seem to get a good grasp of the idea of the overflow concept. Your reply helped tremendoulsy. Thanks to you also, rdrast, for your reply. Thanks again fellas and God Bless!
I've got a Powerflex 700 that doesn't like to get going in the mornings. This motor will run anywhere from 30 seconds to 5 minutes before it just...
171
Not a PLC question but I need expert help on this. My FactoryTalk stopped communicating with the server its hosted on. I had an error stating...
107
Hi! I am trying to run the 'SimpleSample' (https://infosys.beckhoff.com/content/1033/TF5100_TC3_NC_I/Resources/3438746891/.zip ) to understand the...
106
Hi guys! I have 3 servos for X,Y,Z axis controlled by Kinetix 5500. In Studio 5000 there is one Predefined tag in AXIS_CIP_DRIVE called...
156
Hi everyone i have a customer, who wants to show an alarm on the machine, if the I/O forces are enabled and set, on at ControlLogix L81E with...
261
