plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old January 3rd, 2018, 02:23 AM   #1
f.fabunmi
Nigeria
f.fabunmi is offline
Wincc runtime advance v13
Dear all,
in my current project i am using S7-1200 controller, but i want to use normal PC as my HMI. On my engineering PC I have installed TIA PORTAL V13 SP1 UPD9 for both STEP 7 and Wincc. my question now goes thus, on the station PC i want to use as an HMI what are the necessary software i need to install there to be able to have successful connection to my controller. I believe i need to install wincc runtime. Nevertheless, i am seeking for experts guide on this... Thanks in advance.
Regards,
Femi.
Old January 3rd, 2018, 02:45 AM   #2
dbozic
Croatia
dbozic is offline
Yes you are right.
You need to have Wincc Runtime Advanced or Professional installed on the PC.
Old January 3rd, 2018, 03:08 AM   #3
kalabdel
Canada
kalabdel is offline
What dbozic said and for more information:
Comparison
Old January 3rd, 2018, 04:36 AM   #4
f.fabunmi
Nigeria
Quote:
Originally Posted by dbozic View Post
Yes you are right.
Thanks.. But question has not been fully answered sorry for that.... Do I need to install another software beside wincc runtime advance?
Regards,
Femi
Old January 3rd, 2018, 12:56 PM   #5
kalabdel
Canada
kalabdel is offline
You do not need any more software installed. You didn't specify which version of TIA/WinCC you have installed on your programming environment. But the requirements are right here
If you're not running SCADA on your PC station then runtime advanced will do if you are then professional is needed.
Old January 3rd, 2018, 02:29 PM   #6
f.fabunmi
Nigeria
Thanks.. I am running wincc advance v13 sp1 upd9 on my engineering PC. But should I first install wincc advance v13 sp1 upd9 on the PC I intend using for runtime before installing RT advance.. I have tried to install only wincc RT advance on that PC but it giving me some error..
Old January 3rd, 2018, 02:34 PM   #7
kalabdel
Canada
kalabdel is offline
You should install only the runtime version. How about a screenshot or the errors?
Old January 3rd, 2018, 02:37 PM   #8
f.fabunmi
Nigeria
OK.. I will try to reinstall and send the screenshots of the error to you shortly
Old January 3rd, 2018, 02:58 PM   #9
f.fabunmi
Nigeria
Quote:
Check the attached for error message
Old January 3rd, 2018, 02:59 PM   #10
f.fabunmi
Nigeria
Have sent the error message... Thanks you
Old January 3rd, 2018, 08:42 PM   #11
kalabdel
Canada
kalabdel is offline
At what stage do you get that error?
To not waste time, go back to basics. Make sure you operating system is supported, make sure your installation files are not corrupted (DVD? ISO?.exe?) if possible just fownload the trial version which is full version from Siemens' site to make sure it's all good and after the installation is successful use your DVD to authorize it. Depending on where the last installation left off you may need to do some work to delete all the old files.
Old January 7th, 2018, 11:42 AM   #12
JBA-DK
Denmark
JBA-DK is offline
With TIA PORTAL V13 basic you can program the s7-1200 and simulate a panel from the same pc. The programming software is cheaper than the wincc runtime. The simulating runs the panel like it was the actual panel.
Old January 7th, 2018, 11:54 AM   #13
f.fabunmi
Nigeria
Quote:
Many thanks JBA-DK.. I really appreciate your response..
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Read Tag comment during runtime in WinCC Flexible RammRras LIVE PLC Questions And Answers 2 June 11th, 2015 09:32 AM
Wincc Runtime to Access Remote HMI Panels hagos LIVE PLC Questions And Answers 8 January 21st, 2015 08:07 AM
Opening older project with WinCC Flexible 2008 runtime... Syrist LIVE PLC Questions And Answers 2 March 24th, 2010 04:15 PM
Help.. WinCC Runtime problem HenkieD LIVE PLC Questions And Answers 0 February 3rd, 2009 03:20 AM
WinCC runtime problem HenkieD LIVE PLC Questions And Answers 0 January 6th, 2009 10:42 AM
