Red Lion CR3000 HMI Serial to Mitsubishi FX3u PLC
woolie161
Aug 2012
Eltham
73
Hi All,
I am looking to install a Red Lion CR3000 HMI and connect it to a Mitsubishi FX3u 64M PLC via Serial. I cannot find confirmation on the Red Lion Website that the CR3000 has the serial driver for this connection.
Is this serial connection possible and has anybody achieved this.
Woolie
The FX3U main port is 422, perhaps it would be worth getting a 232BD board that fits on the left hand side if the crimson has difficulty with 422 it's only about £120.00 so reasonable, this also allows having both the programmer & the HMI connected at the same time (if Crimson does not support passthrough).
Thank you to both Steve & Parky for the replies.
Looks like I will be playing with "stuff" over the weekend, to look at Red Lion Drivers & to investigate the 232 module.
Again Thank you for taking the time to reply.
Woolie
The 232-BD board when fitted defaults to programming protocol at 9600 baud,
If you want a hifgher speed then there are "D" registers in the 8000 range (cannot remember which ones) where programmatically in ladder you can change things like protocol, baud, parity etc. but for most purposes it can be left at default if not too much traffic between HMI & PLC.
Hello All, I need the ability to remotely reboot a Red Lion CR3000 HMI. Due to some graphics issues when the database is updated the HMI must be...
219
Hello, We are currently running a bunch of g310's connected to their SLC5 PLCs through ethernet. I've attempted to upgrade the program from 2.0...
1,121
Hi I have been using Red Lion products for some time, I had a thought over the bank holiday weekend, As you do. It would be nice if whenever a...
1,017
Hi everyone, I have a Red Lion CR3000 HMI that I am trying to set up to send a email when there are certain alarms. So far I have had no luck...
4,446
Hey guys, I am currently trying to set up a CR3000 to be viewed from from any where in the world. I am able to view the HMI locally (across my...
2,156
