Magelis runtime setting
claus_lind
Jan 2017
Hasle
Hi all..
I now have 2 xbtgt 6330 that has "burned lampe".
The problem now is that the lamps for this panel are not available as a spare part anymore.
Since this has left this panel in a state where I cant acces the setting in the runtime config , where I can disable the setting that disables the touch (clear ?) via the touch panel.
Is there a way to "set" the bit that enables the touch even if the panel see a "burned lamp"? can not see any i Vijeo.
I have made new light with led, but cant use the hmi now!!.
The HMI is only going to be used for info screens,but with multiple pages,so there is no security problems.
Best regards
Claus Lind
On for 24/7 in 5 years, placed on a ferry.. Funny thing 2 screen out within 2 month !!! Timer inside ?:)
But why cant I get in and change the burned bit....
Best regards Claus
You can get the lights still. In my experience most of the time the power supply for the lights are faulty. We started buying them from China. Open the screen and look for the card the 2 light tubes plug into. Search google for that part number. Heck of a lot cheaper than buying a new 15inch screen
I am having trouble running the application throught my PLC, tm221me32tk with magelis HMIGTO6310 I have prepared the plc programme, also created...
109
Good morning friends. . We are having a problem with one of our machines that have two HMI consoles connected to the same network. They have...
1,117
I am looking at a bakery oven that has been dismantled and in storage for unknown time, it was manufactured in 2012 so not that old. my gig is to...
3,618
Any regular users of the magelis range? If so, anyone have a slick way to do a common popup with a rockwell UDT? My current approach is to just...
1,650
We're a second hand machinery merchant. We've just had a machine arrive that has a Schneider Twido TWDLCAA24DRF PLC and a Magelis XBT-R411 HMI...
2,399
