SSI absolute encoder connection to S7-1500 system ?
Ken Roach
Apr 2002
Seattle, WA
17,480
I'm being asked to bid a control system using Siemens S7-1500 controllers, which I don't have any experience with.
The digital, analog, and Profibus I/O are things I can figure out, but I don't know how to connect an SSI encoder to an S7-1500. This control system requires four of them.
They aren't doing motion control; they're strictly to monitor speed and position of two parallel machine elements.
I see that there's a "SSI Technology Object" that looks like a feature you have to enable in the S7-1500.
But what I/O module can I use to connect an SSI encoder ?
The 1500MP local I/O is exactly what I need; somehow the menus I was looking at didn't include the Technology Modules.
Extended questions: this is a super-high-vibration environment. I know there's a high-temperature S7-1500. Is there a ruggedized one ?
Optional extended question: what's the most rugged field I/O system for S7-1500 ? When I say "high vibration", I mean "on fire being struck with a hail of sledgehammers".
An interesting link.
I knew about SIPLUS but not about SIPLUS extreme RAIL.
I notice that there is avariant for ET200SP. I wonder what the vibration resistant elements are, because I have found regular ET200SP to be sensitive to vibrations.
edit: Actually, they only mention that there is a vibration resistant CPU. Nothing about i/o modules. That could confirm that ET200SP simply isnt well designed to be resistant against vibrations.
I have an absolute encoder that is connected via SSI to a computer. Has anyone seen a PC card that transmits SSI so that I can create an...
3,373
Hi Guys I am using SICK absolute encoder ATM 60 with an SSI to Parallel Converter (AD-SSIG-PA) to connect to a Mitsubishi Q02HPLC. The set up...
6,363
Good evning everyone, i need some help, dont know what to do!! Yesterday we were going to do some changes on a machine at my work, we tried it...
7,317
Hi. Can anyone explain how an Absolute Encoder works with the SSI interface and what Grey code is all about?
9,983
Hi all, I have an application coming up where I have a motor that runs forward or backward to adjust the linear position of a machine component...
1,299
