SSI absolute encoder connection to S7-1500 system ?
Ken Roach
Apr 2002
Seattle, WA
17,490
I'm being asked to bid a control system using Siemens S7-1500 controllers, which I don't have any experience with.
The digital, analog, and Profibus I/O are things I can figure out, but I don't know how to connect an SSI encoder to an S7-1500. This control system requires four of them.
They aren't doing motion control; they're strictly to monitor speed and position of two parallel machine elements.
I see that there's a "SSI Technology Object" that looks like a feature you have to enable in the S7-1500.
But what I/O module can I use to connect an SSI encoder ?
The 1500MP local I/O is exactly what I need; somehow the menus I was looking at didn't include the Technology Modules.
Extended questions: this is a super-high-vibration environment. I know there's a high-temperature S7-1500. Is there a ruggedized one ?
Optional extended question: what's the most rugged field I/O system for S7-1500 ? When I say "high vibration", I mean "on fire being struck with a hail of sledgehammers".
An interesting link.
I knew about SIPLUS but not about SIPLUS extreme RAIL.
I notice that there is avariant for ET200SP. I wonder what the vibration resistant elements are, because I have found regular ET200SP to be sensitive to vibrations.
edit: Actually, they only mention that there is a vibration resistant CPU. Nothing about i/o modules. That could confirm that ET200SP simply isnt well designed to be resistant against vibrations.
I have an absolute encoder that is connected via SSI to a computer. Has anyone seen a PC card that transmits SSI so that I can create an...
3,384
Hi Guys I am using SICK absolute encoder ATM 60 with an SSI to Parallel Converter (AD-SSIG-PA) to connect to a Mitsubishi Q02HPLC. The set up...
6,392
Good evning everyone, i need some help, dont know what to do!! Yesterday we were going to do some changes on a machine at my work, we tried it...
7,340
Hi. Can anyone explain how an Absolute Encoder works with the SSI interface and what Grey code is all about?
10,011
Hello, I have a question about an encoder that has absolute measurement. Specifically, it's the Lika SMA5, which I would like to connect...
58
