Interpolation in frequency
dandrade
Jan 2004
374
In manual part about outputs special, for
modulation in pulses.(generator frequency) Have reference models PLC -Interpolation and No interpolation between two outputs.(Y0-Y1)
What interpolation?
Obs: Not reference PWM
hi! Has anyone experience doing linear interpolation for servo motors using omron CJ2M PLC and CJ1W-NJ413 PCU. If you do, can you show me...
161
Hi All, So I am using an Automation Direct BRX PLC (Do-More Designer 2.5), in which I need to calculate the Log Inactivation of Giardia. I am...
3,601
What is the advaantage to increaseing the encoder interpolation value paramenter higher than the default x4 value? Aren't you still limited to...
2,617
How is it done? New positions are downloaded every 2 milliseconds and the motion controller uses this data to compute velocities, accelerations...
35
7,314
hi techies...i am currently working on a project that requires me to drive a 2-axis actuator to perform both linear (in x and y directions) and...
2,097
