Peter Nachtwey
What does MDT stand for? In this case it is not magnetostrictive displacement transducer.
Also, does the master download integer counts or floating point position? Is this an option? There are implications either way. If counts are used then the feedback better be very fine. It the feedback is 32 bit floats then the resolution is dependent on the position. Floating point resolution changes as a funciton as follows: resolution=position/2^24.
